Machine Vision
Labview Interface with Cognex
We want to use Labview as interface visualization of data from an image processing done in Insight environment with a color camera from Cognex.
What are the ways to recover data in Labview from Insight ?
Thank you for your responses.
Message 1 of 20
(21,495 Views)
The question is what does this "In-Sight" software from cognex provide, what interfaces?
There is also an NI Insight -> NI Insight Connectivity VI's
Christian
Message 2 of 20
(21,488 Views)
Christian,
Cognex In-Sight has nothing related to NI Insight except the name!
Just two ideas:
For communication with Cognex as far as I know, you can use In-Sight OPC server. So, you should be able to get data from Cognex through LabVIEW DataSocket.
For more deep communication you can use (probably) In-Sight Explorer SDK (but I don't know what is inside exactly).
And this link may be useful for you:
http://morethanfunctional.org/index.php?/archives/12-Running-Cognex-In-Sight-1721-in-LabView.html
Andrey.
Message Edited by Andrey Dmitriev on 05-19-2010 03:16 PM
Message 3 of 20
(21,477 Views)
Hey Andrey,
What I wanted to point out with my last post was that there are a lot of Insights, which, as you mentioned, very different Smiley Wink
I just wanted chema to be a bit more specific with his question, but it seems that I was not direct enough.
However, as far as I know, I believe Cognex Insight provides an ActiveX Control that you can call in LabVIEW.
I would recommend to contact Cognex too with this question.
Here you can signup -> http://www.cognexsensors.com/support/SmartListManager.php?langtype=1033
Christian
Message Edited by Christian_M on 05-19-2010 08:47 AM
Message 4 of 20
(21,468 Views)
the simple answer is yes you can. either by using the insight sdk or by using native mode commands depending on what you actually want to do. if you just want to read/write cell values then native mode commands is easiest, if you want to actually replicate the insight software in a labview front end then you'll need the SDK
get in touch if you need to buy the SDK.
Message 5 of 20
(20,412 Views)
Somebody ?!?!? , I am looking for some examples for Cognex In-Sight Explorer control via LabView
I have some job file for In-Sight Explorer and I should be able to lunch it and to get the value of specific cell .
Please HELP!!!!!
Message 6 of 20
(19,862 Views)
I find that COGNEX with labview comunicate by activeX, but i don't find how to make Icogimage to Icogimage8grey.
if someone is faced with this problem?
Message 7 of 20
(17,270 Views)
hi , please post that code labview + cognex interface
Message 8 of 20
(17,161 Views)
Hy Guys,
I know it's an old thread, but anyone have an example of how to use labview with a cognex camera?
Thank you!
Message 9 of 20
(15,354 Views)
Hi, i dont have the original code, but it was using Telnet to connect to the camera using the Cognex Native mode commands.
assuming you are talking about an insight camera.
If it is the visionPro software then that is all .net and alot more complicated 🙂
Regards
Stewart.
Message 10 of 20
(15,343 Views)
