01-12-2016 09:34 AM
We have a JAI EL-2800M camera that we are trying to get working in a 4-tap configuration. The camera size is 1920x1280 with a max frame rate of 60 FPS. We are trying to use a NI-1429 or NI-1433 with the camera as CameraLink Medium. The camera supports a 1 tap and 2 tap setting that produces 15 fps and 30 fps respectfully that we can capture in the Camera File Generator. When in 2-tap we use the Interlaced Vertically setting in NI Camera File generator.
The manual for the camera describes the 4-tap configuration as interlaced vertically split horizontally. It is similar to the "4 Tap Split Interlaced Vertically" setting in the Camera File Generator except with the 2 taps as top and bottom, not left and right.
Does anyone have a camera file for this camera (or its color counterpart EL-2800C) or know how to setup the camera file to work with a 4-tap configuration "Interlaced Vertically split horizontally"?
Thanks.
01-13-2016 05:03 PM
Hi Milo88,
I think I have a good idea of the tap configuration, but could you post the manual or a visual representation of the tap configuration. I want to make sure that we are on the same page so that we can see if we can help.
01-13-2016 06:15 PM
Hello FuManWho, Here is a link to the manual, we are using the mono-chrome version of the camera.
http://www.1stvision.com/cameras/JAI/dataman/Manual_EL-2800PMCL.pdf
Page 24 and 25 describe the different tap configruations available. We are able to get 1X_1Y (figure 12) and 1X2_1YE (figure 14) working properly. We get an image off the 1X_2Y3 (figure 13) configuration but the second half of the image is up side down and we are not able to correct it. I assume this issue would also apply the the 1X2_2YE configuration.
We are trying to get the 1X2_2YE (figure 15) configuration working properly.
Thank you,
Sean
