04-17-2014 03:47 AM
Hi, like i ask on the title i need some hint about this. I need to program a simple AOI machine that must inspect a pcb board and find if all the components are correctly placed and oriented. I though to use the pattern matching with a good template of the object to inspect. Can it work?
All kinds of tips that may come to your mind please tell me, because this is the first time i try a task like this. I already have some experience in image manipulation but not in AOI machines.
Francesco.
04-18-2014 03:05 AM
04-18-2014 08:16 AM
Thank you very much Licia. Even if i have already read these links i appreciate the suggestions.
