04-21-2015 10:10 AM
Is NIVBAITestStandAPI.dll compatible with Windows 7 64 bit OS
Solved! Go to Solution.
04-22-2015 08:29 AM
Hello Big_Papa_Craig,
Did you followed some procedure like the one mentioned in section 1 of this following article?
"unning a Vision Builder AI Inspection from TestStand"
http://www.ni.com/tutorial/4007/en/
If you are using TestStand 3.1 or later, complete the following steps:
Is the error you're showing, the result from step 5?
Regards!
>>Daniel
04-22-2015 08:39 AM
Hello Danubio,
I did follow that procure you listed and it is not deteled enough for Windows 7. I figure out and sent my steps back to NI to update "Running Vision Builder in TestStand' tutorial. Below are the step I followed.
