05-16-2017 02:09 AM
Hi everyone.
I design a vi for acquisition my cameras, but I have a problem.
I have a integrated camera (Laptop Webcam) and a ip camera adaptor (From my phone).
Both of cameras grap properly from Labview Devices [bellow image]:
But in my input season for "IMAQdx Open Camera" just shown my integrated camera (cam0) !! [bellow image]
Why this happen? while my cam1 work and listed in labview device and get motion properly.
Please help me,
Thank you all.
05-16-2017 11:13 AM
Are you using 64-bit LabVIEW? It is possible that the camera DirectShow driver only ships 32-bit application support. MAX is a 32-bit application and that might be why it sees the camera. You could try confirming if 32-bit LabVIEW works. If so, you'd have to check with the camera vendor and see how to install 64-bit support.
05-16-2017 11:02 PM
Thank you for your reply,
My LabVIEW version is 2016 64-bit. So, you say MAX can not open the ip camera? because of my version (64bit) or camera driver?
However, what is the solution? how I can input my ip camera (cam1)? Except change version...
Thank you
05-16-2017 11:04 PM
You either need to get a driver for your camera with full 64-bit support (or switch cameras), or switch to 32-but LabVIEW.
