01-14-2015 03:49 AM
in example find pattern matching the angle remaings zero .. even the image is rotated
Solved! Go to Solution.
01-14-2015 07:12 AM
are you using rotation invariant method (also for template calibration)?
K
01-14-2015 06:43 PM
hi Klemen,
1. in vision assistant if i enable Rotate and search . the angle is able to find ..
2. and also i have to give proper template (template created by vision assistant) ..
So . I need to help regarding template creation for pattern matching . Do YOU HAVE ANY vi CODE THAT CREATE AND SAVE TEMPLATE FROM Live Camera Image (Grab ) ..
(Note : in example file of vision i found some code in create template . that one is single image snap and also in event Structure..)
01-15-2015 02:45 AM
see a simple example in the attachment (saved for LV 2012).
Yes, you could also use event based structure.
Hope this helps.
K
01-15-2015 08:26 AM
hi Klemen,,
Thanks a lot for you kind response ..
I am going to work with vision and motion based project (GigE) Camera ..
How to frame the code for Vision and motion ?
How to do Camera Calibration for (1mm x 1mm)? ( In website i have seen some Calibrationn Grid Image )
01-15-2015 08:50 PM
hi Klemen,
for finding angle (rotation invariant method) . whats the angle range i should specify
01-16-2015 01:47 AM
depends on the degree of rotation you expect. Selecting a wider interval of angles, the detection speed will also decrease.
K
