12-04-2007 08:23 AM
I am trying to get the NI PCIe 1427 card to work with my camera (Uniq Vision UF 1000 ,320x240 at 400 fps). I am using IMAQ driver version 3.8. I am not able to get any images from the camera. I open MAX and select the given camera file for the img0 device. Then I press "Snap" (or "Grab") and see the following message:
Error 0xBFF60022
A timeout error occurred while waiting for the specified event. If waiting for an Image, verify that all video data is acquired within the timeout period. If waiting for a signa, verify that the signal assertion occurs within the timeout period.
Do you have any suggestions on what could be causing this error?
Cristian.
07-21-2008 02:37 AM
02-25-2015 08:03 AM
Tryiong to make some image aquisition using the PCI-1409 and a hamamatsu c2741 camera (w. controller).
It used to work just fine using standard CCIR settings but, once changed the computer (the old one is in the bin) I got the 0xBFF60022 error.
Tried changing the cable: didn't work.
I have only one NI window open and, as I said, the CCIR settings used to work. Any idea?
Thanks!
