08-21-2014 02:28 AM
Hello
I want to compare two images. I am able to capture the image using frame grabber, Now I want to verify if the captured image is same as the stored reference image.
Now basically my images will be a specific pattern combination of Red, Yellow , Green, white and Black. I want to compare both pattern as well as the color of the two images.
Currently I am individually extracting each color using IMAQ Threshold from both the images and doing a IMAQ absolute difference to find if both the images are identical.
What is the most accurate way to do this?
08-21-2014 03:28 AM
Have you tried to IMAQ substract, pane by pane? I would try that and then on each of the result images I would histogram variance (or standard deviation) to quantify the difference pane by pane.
See attached VI in LV 2012SP1
Epictetus
08-22-2014 04:09 PM
perhaps you could also give it a go with SSIM (structural similarity) on each seperate color plane? Try looking at IMAQ SSIM.
K
09-01-2014 04:47 AM
Can you please explain what exactly is the score that is returned by the SSIM vi?
Is it only useful for judging the quality of the image or can it also be used for comparison of two different image?
09-01-2014 04:57 AM - edited 09-01-2014 04:58 AM
When you want to know how vision finctions work, a good source is : C:\Program Files\National Instruments\Vision\Documentation\NIVisionConcepts.chm
And it's also on the web : http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/structural_similarity_index/
If you search for SSIM in the help file you will find the formulas and concepts. I am not familiar with SSIM myself so I won't be able to give you more than that, but I'm pretty sure you can find usefull info on the web.
Hope this helps
Epictetus
