Machine Vision
IMAQdx folder not found in MAX
I've installed Labview NI-IMAQdx selected as in figure 1, but the IMAQdx folder didn't show up in the MAX as in figure 2.
What can I do to make IMAQdx folder show up in MAX?
(3,054 Views)
Newer versions of IMAQdx no longer have a dedicated folder show up in MAX. The hierarchy is based on physical topology, but Ethernet and USB devices show up at the root level.
Eric
(3,047 Views)
Thanks a lot. You're right!
(3,038 Views)
