05-08-2014 05:47 AM
Hi All,
It's taking more time to acquire image from a GigE camera using IMAQdx VIs. Following is the configuration of the system.
Camera - IDS camera, model 5480-CP-C-HQ
NIC - Realtek RTL8111B
I have tried with a sample VI (PFA) I could find it is taking nearly 8 seconds to capture the image. Please find attached the the timing details for the capture.
IMAQdx Open - nearly 3 seconds
IMAQdx Snap - nearly 500 seconds
IMAQdx Close - nearly 4 seconds
Is there anyone who has faced this issue? I would appreciate if you could help me in resolving this issue.
05-08-2014 11:21 AM
This camera is not GigE Vision, but rather IDS's own propietary protocol. I am assuming you are using their DirectShow interface to use the camera within IMAQdx. Your VI looks perfectly simple and I don't see any issues with it. Unfortunately this really points the issue to IDS's drivers and/or their interface with DirectShow.
Some other possible alternatives would be to switch to a GigE Vision camera (so IMAQdx interfaces with it directly), or perhaps try IDS's own LabVIEW SDK instead of IMAQdx and see if it works better.
Eric
05-13-2014 04:41 PM
Do you know if the case it takes longer to IMAQdx to capture the image is also presented in some type USB cameras?
For USB cameras, they must be USB Vision certified, or meet some kind of certificatified complaint?
05-13-2014 09:26 PM
