02-16-2011 03:10 AM
Some attributes of my camera our shown in the camera's software (DALSA CamExpert) but aren't displayed in MAX.
When I open the xml file I do not see a difference between the shown and hidden attributes.
Why doesn't LabView display all possible attributes?
Does the sml file has specific requirements?
Any ideas?
Solved! Go to Solution.
02-16-2011 10:53 AM
Hi Kim,
What camera are you using? Can you post the XML file and the names of the features you are unable to access?
Eric
02-17-2011 01:50 AM
Hello Eric,
I fixed the problem yesterday!
I'm using a DALSA camera. The Dalsa software downloads the XML file and saves it in a 'dalsa' directory on my local disk.
National instruments software (MAX) downloaded the XML file and saves it in an other directory. The 2 files weren't equal. I replaced the NI XML file with the Dalsa XML file and now I'm able to get all attributes.
But thanks for your reply!
Kim
02-17-2011 09:49 AM
Hi Kim,
It is possible that the Dalsa software had an updated XML file built-into the software that was being used instead of the one onboard the camera. You could possibly check with Dalsa if they have a firmware update for the camera that can update the onboard one to the same version so then the camera will work out-of-the-box in the future.
Eric
