03-31-2017 08:57 AM
Hi all,
I need some help with the IMAQdx palette
I created a Class for a Camera using the IMAQdx palette and I would like to use the dynamic call for this class.
Meanwhile I'm working in the development mode is all ok. The problems start with the EXE file. It seems that if the IMAQdx vi aren't included in the main code, then they result as missing.
The problem is that I need to use the dynamic call because of my systems use different cameras and for some of them I'm not using the IMAQdx driver.
I hope my explain is clear.
There is some solution?
Thank you
04-05-2017 12:38 AM
04-05-2017 01:15 AM
Hi udka, thank you for your replay
-Your Development machine and Target Machine are same or different? What are the configurations?
Yes and No, but I have the problem also on the development machine
-Which version of IMAQdx you are using?
August 2014
-Do you have proper license for Vision Acquisition Software?
Yes, sure
-Refer this link for more on Licensing: http://digital.ni.com/public.nsf/allkb/F1699570F78FECBB86256B5200665134
I build my class as source distribution and than i call it dynamically in my main code.
Doing this, when I use the EXE, labview doesn't find the IMAQdx vi
04-05-2017 01:41 AM
04-05-2017 02:18 AM
udka ha scritto:
What error you get? Post screenshot of it.
It just appears the file browser popup asking for the IMAQdx vi I included in my code
-Do you have Vision Runtime Engine installed?
Yes.
04-05-2017 03:00 AM
For your application to run as an EXE in a stand-alone environment, you will need to have the following software installed on the target machine:
Ref:http://digital.ni.com/public.nsf/allkb/62A62C6EC72156A78625774C0058693B
-In NI MAX see in Software section and verify IMAQdx Runtime is installed.
