Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
04-21-2016 02:22 AM
When I use the IMAQ Match Pattern 4 VI, there had an error like this:
what is wrong with this? How should I do ?
would you help me?
04-21-2016 10:47 AM
Looks like LabVIEW/Vision bug caused exception in C++ Run-Time.
Can you please post minimal snippet of the code and probably image where this exception can be reproduced?
Is it happened with all images or with particular images?
05-06-2016 03:18 AM
Thank you for your answer.
And now I have found the reason of the error,it was the camrea had some problems,and it caused the image was not complete.
Thanks!
We'll be in touch soon!
