12-12-2014 04:56 AM
One probable reason as to why you are getting more particles than expected is because you are sending a grayscale image through particle analysis
rather than a binary image. I had pointed this out in the previous reply only.
Just because I said put a probe and check doesnt mean you check at that single point only. You need to verify the results at every point by using probes, if required.
No solution is ready-made. So you need to try and test a few times/techniques.
I am sorry I have not used the NI particle training interface.
Regards
Aveo
06-26-2015 10:13 AM
Hello I am learning LV right now and my instructor has LV 2010 version.
I coudn't open the VI (provided in this topic discussion) with this version.
Can someone provide me screenshot of the custom classify.VI block diagram?
This way I can learn how to create a simple classification algorithm using LV.
06-28-2015 11:35 PM - edited 06-28-2015 11:42 PM
I can send a 2010 version. but i'm unable to understand which program yor want? there are so many vis attached/mentioned in the posts. can you specify the name of the vi?
Regards
Aveo
Edit: ok i saw you mentioned custom classify.vi. I am attaching a 2010 version of it. please check it out and let me know if it works.
06-29-2015 08:35 AM
Hello aveo,
Thank You very much for the old version file.
I just run the NI updates and found that we have access to LV Machine Vision runtime module 2013.
I hope this will make some positive changes.
Another question:
Can I run Vision assistant five times simultaneously?
I am afraid that ''Classifier session not closed'' error will come up if I do it.
If I can't do it, Is there any other way to work that out?
Thanks again
06-29-2015 11:19 PM
The classifier session not closed error comes up when the classifier file has not been disposed off. It is essential to dispose the classifier file after every use. I dont understand your problem regarding vision assistant, however I can assure you that if you use classification in LabVIEW and use IMAQ dispose classifier file session then you will not be prompted with the error.
Try to create a labview version of everything that you do in vision assistant(it should be possible), and then make sure that the classifier file is disposed.
Regards
Aveo
06-30-2015 08:24 AM
Thank You for the answer aveo.
05-20-2018 03:20 AM
@Klemen wrote:
Hello aveo,
I got around doing some classification testing and maybe this can help you in your project somehow.
I have followed the paper algorithm to create a feature vector:
or
http://hal.archives-ouvertes.fr/docs/00/75/25/09/PDF/118.pdf
I am attaching this vi.
Then I created custom classifier using two examples of built feature vectors, trained the nearest-neighbour classifier and classified the sample (see the attached vi also).
K
@Klemen wrote:
Hello aveo,
or
K
hello Klemen,
i want to know how to classify animals for real time image recognition with labview and how to train classifier image .i have some problem for my project . Please reply to me.
HL
