Machine Vision
IMAQ classify VI concept needed
One probable reason as to why you are getting more particles than expected is because you are sending a grayscale image through particle analysis
rather than a binary image. I had pointed this out in the previous reply only.
Just because I said put a probe and check doesnt mean you check at that single point only. You need to verify the results at every point by using probes, if required.
No solution is ready-made. So you need to try and test a few times/techniques.
I am sorry I have not used the NI particle training interface.
Regards
Aveo
Message 21 of 27
(1,752 Views)
Hello I am learning LV right now and my instructor has LV 2010 version.
I coudn't open the VI (provided in this topic discussion) with this version.
Can someone provide me screenshot of the custom classify.VI block diagram?
This way I can learn how to create a simple classification algorithm using LV.
Message 22 of 27
(1,409 Views)
 I can send a 2010 version. but i'm unable to understand which program yor want? there are so many vis attached/mentioned in the posts. can you specify the name of the vi?
Regards
Aveo
Edit: ok i saw you mentioned custom classify.vi. I am attaching a 2010 version of it. please check it out and let me know if it works.
Message 23 of 27
(1,387 Views)
Hello aveo,
Thank You very much for the old version file.
I just run the NI updates and found that we have access to LV Machine Vision runtime module 2013.
I hope this will make some positive changes.
Another question:
Can I run Vision assistant five times simultaneously?
I am afraid that ''Classifier session not closed'' error will come up if I do it.
If I can't do it, Is there any other way to work that out?
Thanks again
Message 24 of 27
(1,366 Views)
The classifier session not closed error comes up when the classifier file has not been disposed off. It is essential to dispose the classifier file after every use. I dont understand your problem regarding vision assistant, however I can assure you that if you use classification in LabVIEW and use IMAQ dispose classifier file session then you will not be prompted with the error.
Try to create a labview version of everything that you do in vision assistant(it should be possible), and then make sure that the classifier file is disposed.
Regards
Aveo
Message 25 of 27
(1,352 Views)
Thank You for the answer aveo.
Message 26 of 27
(1,328 Views)
@Klemen wrote:
Hello aveo,
I got around doing some classification testing and maybe this can help you in your project somehow.
I have followed the paper algorithm to create a feature vector:
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=5376498&url=http%3A%2F%2Fieeexplore.ieee.org%2...
or
http://hal.archives-ouvertes.fr/docs/00/75/25/09/PDF/118.pdf
I am attaching this vi.
Then I created custom classifier using two examples of built feature vectors, trained the nearest-neighbour classifier and classified the sample (see the attached vi also).
K
@Klemen wrote:
Hello aveo,
or
K
hello Klemen,
i want to know how to classify animals for real time image recognition with labview and how to train classifier image .i have some problem for my project . Please reply to me.
HL
Message 27 of 27
(645 Views)
