02-10-2014 09:27 AM
Guys - can someone please test. Mean and Standard deviation give good numbers. Min and Max are both showing zero (0).
Don
Solved! Go to Solution.
02-10-2014 11:13 PM
02-11-2014 07:01 AM - edited 02-11-2014 07:01 AM
Yes, that is it. Thank you. It makes no sense to me that min/max would not be calculated as part of a block statistics analysis. Have no idea why such a switch would exist, therefore did not even consider this possibility. Perhaps the calculation is more rapid without including min/max calculation.
Sincerely,
Don
