04-22-2015 07:44 AM
Hi
I work with spherical objects with a dimeter size equal to 100 micrometers. The objects are immersed in a fluid. They are movable, swimming in the fluid. I would like to track one of them, masking the others. Could somebody give me an advise how to do it?
04-24-2015 12:47 AM
04-24-2015 04:30 AM
sincu you did not attach any images it's hard to say, but check this out (a toolkit i've made, wrapping various OpenCV functions):
You could use camshift/meanshift tracking based on hue-saturation histogram backprojection, or perhaps you could just try masking your image with backprojection only.
Spherical - since you are processing in 2D space, you can also try using Hough circle transformation to detect the circles and track them on subsequent frames using for example Euclidean distance from detected centers as your criteria.
Can you post a sample image?
K
