NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
labmaster
Accepted Solution
How to set ROI
I "just" installed vison toolkit in LV2011 to get the digits information on LCD panel.
As a starting point, I opened "LCD example" and was modifying.
However, ROI seemed to be important concept in vision.
Do ROI should be measured relative to top-letf postion?
However, can you tell me how can I check ROI in the image.
Enclosed is the example for overlay of ROI on the imagge.
I wanted to set the whole/part of region as the initial ROI then tried to check if "get LCD ROI.vi" is working rightly.
but it failed to display the initial ROI on the image.
How can I fill out the ROI descriptor to set a region on the image?
Image: sample of poor quality - 640*480 jpg
labmaster.
*)Additional question: from a example code, I found initial ROI should be set properly to identify the numbers.
Can you tell me the following...?
1) rule of thumb to set ROI on an image for good recognition of numbers. (for example, only digit area...)
2) can I make the code for finding the initial ROI (related to well-recognition) automatically?
Active Participant
labmaster
Re: How to set ROI
I found the problem was solved after rebooting and I would like to get the reply on the additional question.
In my example code, how can I enhance the reliability in detection?
labmaster.
Active Participant
labmaster
Re: How to set ROI
Changed the idea to OCR.
Do not try with 7digit LED functions.. Can be applied for very limited image.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
