02-20-2013 09:25 AM
*Edit to the above post*
I mistyped and it is IMAQdx 4.1 that will contain the "open by IP address" session syntax.
Eric
02-21-2013 06:04 AM
Thank you , Eric. That will work perfectly.
02-11-2014 08:24 AM
Eric
Hi Eric,
I have IMAQdx 4.2 installed, and can't see how to do this. Did this feature make it in?
Chris
02-11-2014 02:00 PM
Yes, just pass the "ip:<camera_ip_address>" syntax described earlier in this thread to the session name.
04-12-2017 04:35 AM
Hey guys,
about this Topic, because i have the same Situation - i wanted to make the camera session Independent from any MAX identifier.
Just wanted to add the following, because i was stumbling at a specific Point (once again):
Example-String: IP or MAC-Address
ip:192.168.0.1
uuid:001122334455
Very important, maybe applicable in general:
When you open a camera Connection independently from MAX you need to set the
AcquisitionAttributes::PacketSize
to the maximum value your Network Environment is providing, or any desired within this Limits, unless your Environment is supporting Jumbo Frames.
If you dont do this, you will be able to connect, but your code will freeze when you try to snap or configure grab.
Just wanted to Point this out, because i always fall for this 😉
cheers
