Hi there,
You can track objects with just one camera, two cameras are used for analyzing the depth of an object (unless necessary for your application, in which case I would recommend checking this webcast: 3D Vision and Kinect).
For telemetry, here is another resource that can help: Making Measurements on the Image. Since you are getting started check the “Table of Contents” link for more information and key concepts.
Also, there are a lot of examples out there that can get you started, for example:
- Community: Googly Eyes (Powered by LabVIEW)
- object tracking using labview using camera
Last but not least, the software components that you need from NI are: LabVIEW (development environment), Vision Development Module (add-on for vision functions) and Vision Acquisition Software (driver that talks to cameras). You can download this software from the NI website and use it in evaluation mode. If you are interested in the licensing, here is more information: Licensing National Instruments Vision Software
I hope this helps to get you started
Alejandro C. | National Instruments
