Machine Vision
How to do OCR for an Rotatioanl String
Problem in tarining OCR for Roational String  for eg. "HELLO WORLD"OCR_Test.jpg
Message 1 of 9
(4,357 Views)
Problem is in training step or detection step?
-I think in training step you can use rotated rectangle and select characters.
-In detection i don't see any way other than maybe using pattern match and get the text orientation and rotate image back to that and see.
-Did you try giving rotated rectangle as ROI descriptor during detection step and check? (I'm not sure if it works).
uday
Message 2 of 9
(4,344 Views)
Its not a problem unless and until you share what you are doing.
If you are manually teaching/training each character in LabVIEW then you can set the orientation for the search alphabet.
In past we had worked on rotated patterns and mirror patterns as well so I dont think this will resist you if you are using NI VISION VIs.
Please share what exactly you are doing this training.
Message 3 of 9
(4,332 Views)
I am trying to teach via Vision Assistant but couldnt able to get the characters  being extracted to train single character.
Message 4 of 9
(4,329 Views)
Looking like a bug or i might be missing something.
-Instead of training from Vision assistant try the ocr training interface separately.
-You can select the rotated rectangle and rotate and train.
-Where as when called in Vision assistant not able to use rotated rectangle.
uday
Message 5 of 9
(4,322 Views)
Thanks udka,
I used NI OCR Training Interface and i can able to rotate the rectangular tool, can able to detect character and train.
Is there a way to set the ROI dynamically/ Programmatically based on the Rotated angle as used in training portion
Message 6 of 9
(4,280 Views)
As i previously stated you might use pattern matching to get the orientation of text and then give the result ROI Descriptor of OCR Read Text VI.
uday
Message 7 of 9
(4,277 Views)
As I know about OCR you should have good pattern of Alphabets that you would like to teach.
Since you are teaching a rotated pattern and then struggling to set the rotated ROI programatically inspite of this you can teach a straight pattern and set the rotated angle within which you want to find the rotated alphabet.
Example:
Suppose I have an alphabet 'A'. I will teach 'A' as it is(without rotation) with a default ROI rectangle.Now during a search OCR operation I would put the same ROI rectangle by adding +/- rotation angle suppose 45 degree. This will give me a freedom of searching  a pattern 45 degree left and right rotated alphabet.
I hope this might help.
Message 8 of 9
(4,273 Views)
Thanks for all your replies, i will try and get back if i face issue or if my issue gets resolved
Message 9 of 9
(4,267 Views)
