04-03-2014 01:06 AM - edited 04-03-2014 01:22 AM
I'm working with 16 bit grey scale images in VBAI. In configuration mode, there is an option on how to handle 16 bit display mapping, and it works very well to preview the effect of the different display possibilities. However, those settings do not carry over into inspection mode. In the custom inspection interface, if I right click on the image display area it also has an option for 16 bit image mapping, with a default value of "Full Dynamic". It allows me to choose something else, but if I save the custom interface and reopen it, the value always reverts back to "Full Dynamic" For the time being, I've worked around it by adding a vision assistant step to convert the 16 bit image to 8 bit, but I would really prefer to take this step out. Are there any tricks to getting the image mapping setting to work properly within the custom interface? Thanks, Jason
04-03-2014 07:59 AM
