07-23-2012 01:56 PM
07-23-2012 05:37 PM
I am using 2009 labview and windows 7. I found that activexreference function is installed and when I run the thermovisionopen.vi function with the light bulb, it runs but shows the error as failed to connect camera error code#1.device not present. I dont know what is that error code#1. And also when I connect the camera to PC thro firewire. I get 2 camera identifications under NIIMAQdx in MAX. one with the directshow bus type and the other with firewire bustype. But the firewire bus type shows a black image with some lines on it(but I can see the image - not very clear) and with the directshow shows a perfect image. which camera SN I have to enter. But I tried using both, both off them shows up the error.
07-23-2012 05:48 PM
Hello Nichoo,
I'm not familiarized with this toolkit, does it run by itself or are you using any of our Vision software? If not, you could also try asking FLIR for support.
Have a good day!
07-24-2012 02:34 AM
07-24-2012 05:38 PM
hello ULfn, this is what i got.. But I am using firewire conn not GPIB
Error 0 occurred at ThermoVision Open.vi
Failed to Connect Camera. Error Code #1, "Device not present"
Possible reason(s):
FieldPoint: Success
LabVIEW: Error connecting to GPIB driver or device.
Motion: No Error.
Motion: No error.
NI SoftMotion: No error.
NI-488: Error connecting to driver or device.
VISA: (Hex 0x0) Operation completed successfully.
07-25-2012 02:18 PM
07-25-2012 08:58 PM
Hi Ulfn,
I have attache the picture of the thermivisionopen.vi function showing error even afetr entering the parameters.
07-25-2012 09:05 PM
Ulfn,
I am getting the image in MAX.
07-26-2012 07:03 AM
Hi Guys,
I'm the guy who opened this thread. In meantime I solved all the problems and build the tester. I'm using a FLIR A615 to take an IR image before and after heat-up an automotive heater and then doing various analysis with the data (comparison with an " golden template ", uniformity of heat zones, average and maximum temperatures in different areas, delta heat for certain spots, etc..)
The tester is validated and running at full capacity in our production facility and I'm actually building a second machine now.
So, if you need any help, let me know and I'll try to help you as much as I could. Regards.
07-26-2012 09:07 AM
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
