Machine Vision
How to Compare two images and display results
Guys one more important thing is that Slip Yokes have different Weight,Length,Height,Width,Avg. Thickness. This would help you to suggest solutions.
Message 11 of 16
(3,558 Views)
I will create a Vision Assistant script but need for you to retake the photos.  Retake the photos with the yoke on a solid white background.  ZIP all photos together and post.  The current photos don't have good contrast from the part under inspection to the background.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 12 of 16
(3,530 Views)
let me know if you need it in other angles or any other specification
Message 13 of 16
(3,516 Views)
There are too many things wrong with your images for an accurate and repeatable match.  My recommendations would be to use a better quality camera, back light product (see attached image), capture image in 8-bit resolution, and use grayscale pattern matching. I tried several techniques but need to start with a higher quality image.
Matthew Fitzsimons
Message 14 of 16
(3,478 Views)
please check out the images
Message 15 of 16
(3,393 Views)
Please if possible send the vi file which you have developed.Its dead line time.I will try to continue with your viSmiley Sad
Message 16 of 16
(3,347 Views)
