10-09-2015 01:28 AM
Guys one more important thing is that Slip Yokes have different Weight,Length,Height,Width,Avg. Thickness. This would help you to suggest solutions.
10-13-2015 01:52 PM
I will create a Vision Assistant script but need for you to retake the photos. Retake the photos with the yoke on a solid white background. ZIP all photos together and post. The current photos don't have good contrast from the part under inspection to the background.
10-16-2015 07:27 AM
let me know if you need it in other angles or any other specification
10-23-2015 11:00 AM
There are too many things wrong with your images for an accurate and repeatable match. My recommendations would be to use a better quality camera, back light product (see attached image), capture image in 8-bit resolution, and use grayscale pattern matching. I tried several techniques but need to start with a higher quality image.
10-30-2015 04:03 AM
please check out the images
11-04-2015 06:57 AM
Please if possible send the vi file which you have developed.Its dead line time.I will try to continue with your vi
