05-24-2016 02:54 AM
Here is the code I am working with:
#include <opencv2/imgproc/imgproc.hpp> #include <opencv2\highgui\highgui.hpp> using namespace std; using namespace cv; // extern C extern "C" { _declspec (dllexport) int MyHistCalc(unsigned char *imageIN, int rows, int cols, double threshold1, double threshold2, int kernel_size, unsigned char *imageOUT, unsigned char *HistCalcImageOUT); } _declspec (dllexport) int MyHistCalc(unsigned char *imageIN, int rows, int cols, double threshold1, double threshold2, int kernel_size, unsigned char *imageOUT, unsigned char *HistCalcImageOUT) { Mat image_input(rows, cols, CV_8U, &imageIN[0]); // THIS IS THE INPUT IMAGE, POINTER TO DATA Mat image_output(rows, cols, CV_8U, &imageOUT[0]); // THIS IS THE INPUT IMAGE, POINTER TO DATA Mat image_histcalcoutput(512, 400, CV_8U, &HistCalcImageOUT[0]); //Mat gray = imread("image.jpg", 0); namedWindow("Gray", 1); imshow("Gray", image_input); image_output = image_input; namedWindow("Image Output", 1); imshow("Image Output", image_output); // Initialize parameters int histSize = 256; // bin size float range[] = { 0, 255 }; const float *ranges[] = { range }; // Calculate histogram MatND hist; //hist is a 256x1 array calcHist(&image_input, 1, 0, Mat(), hist, 1, &histSize, ranges, true, false); // Plot the histogram int hist_w = 512; int hist_h = 400; int bin_w = cvRound((double)hist_w / histSize); Mat histImage(hist_h, hist_w, CV_8UC1, Scalar(0, 0, 0)); normalize(hist, hist, 0, histImage.rows, NORM_MINMAX, -1, Mat()); //image_histcalcoutput = hist; for (int i = 1; i < histSize; i++) { line(histImage, Point(bin_w*(i - 1), hist_h - cvRound(hist.at<float>(i - 1))), Point(bin_w*(i), hist_h - cvRound(hist.at<float>(i))), Scalar(255, 0, 0), 2, 8, 0); } image_histcalcoutput = histImage; namedWindow("CalcHist Result 1", 1); imshow("CalcHist Result 1", histImage); namedWindow("CalcHist Result 2", 1); imshow("CalcHist Result 2", image_histcalcoutput); waitKey(0); return histSize; }
I am unsure if my problem is catching image_histcalcoutput incorrectly in LabVIEW or returning result correctly.
Please find screenshot of my VI attached.
05-24-2016 06:34 AM
05-24-2016 08:17 AM
My question (and implementation) is part of a bigger problem with portions already utilising OpenCV.
05-24-2016 10:05 AM
