10-10-2009 09:43 AM
Hi
I am using the NI Vision Assistant. Here I wanna overlay an existing image with another one. Therefore I use the overlay setup where I can import a .png image. If I do so I do not get
the transparent background of the image back, even I has been saved with transparency background. The image is shown with an orange background.
If I import the same picture to any frontpanel for example, I see the picture in the right way with a transparent background. What I do wrong? I attached the image which I would like to use.
thanks
10-11-2009 07:14 AM
Hi! Not sure how to do this in Vision Assistant. Try to use overlay (bitmap) or convert your image to mask. Transparency effect not supported in Vision. What you can do in LabVIEW is something like that:
10-11-2009 07:53 AM
Hi Andrey... this was exactly what I was looking for, even it is not working for the vision assistant I think I can use it.
thanks..!
10-12-2009 03:56 AM
this is maybe due to the image type you are using. Under the following link you will find additional information about NI-IMAQ Supported File Formats.
http://digital.ni.com/public.nsf/allkb/4EEF7CB578DCDC5E86256D05000D3AE5?OpenDocument
Best regards, Stéphane
10-12-2009 09:40 AM
Stephane,
I tried to save the image in different formats, even with an alpha channel - without success. Do you have an example image which I could try to import in the Vision Assistant?
regards
10-13-2009 01:49 AM
Norick,
Can you mark andrey's reply as the solution?
12-20-2011 05:58 PM
I'm trying to do something very similar, but I want to overlay I colour image with transparency. This solution only seems to work for greyscale...
Any ideas?
Steve
03-01-2014 01:59 PM - edited 03-01-2014 02:03 PM
