NI Home
Cart Cart | Help
You are here:
Reply
Frank_Noe
Gige vision camera fails with trigger on
i have gige vision camera sca640-70gc and when i set the trigger mode on it gives fail with line1 and line2 while with trigger mode off it works ok
toto26
Re : Gige vision camera fails with trigger on
Do you provide a trigger signal on the dedicated input line of your camera such as a TTL signal?
Regards
Frank_Noe
Yes i do. and tried both direct trigger from the PLC and terminal block as well and it gives same result(fail)
Silver_Shaper
Re: Re : Gige vision camera fails with trigger on
[ Edited ]
Hi Frank,
Is your camera triggers works in pylon viewer?
Sasi.
Certified LabVIEW Associate Developer
If you can DREAM it, You can DO it - Walt Disney
