Machine Vision
Get the new coordinate after rotation
hello master:
  i had thought about this question and try to calculate it for two days. but i still can't get the right coordinate.
picture 1.bmp, the coordinate of point "P" and point "Q" is known.
after we rotated with 337.96289 degree, i took a picture 2.bmp, the coordinate of point "Q" in 2.bmp is known. now how can i calculate the coordinate of point "P" in 2.bmp? this problem was suffering me. it will be very appreciated for any help or suggestion. thanks.
(3,853 Views)
knowing one point coordinate will not help you to find other points based on that point
for 2D area you need at least two known point or one point +rotation angle (theta) to find other points positions and for 3D you need at least 3 point or one point +two vertical rotation angle
(3,827 Views)
Accepted by topic author Time_Walker
Something like this:
Create vector from first points which is distance from Q to P:  V(x,y) = P(x,y) - Q(x,y)
Create rotation matrix M using T=rotation angle:  First row = cos(T) sin(T)  Second row = -sin(T) cos(T).
Multiply matrix times vector:  Vnew(x,y) = M[2*2] * V(x,y)
Add Vnew to Qnew to get Pnew: Pnew(x,y) = Qnew(x,y) + Vnew(x,y)
I may have negative sine in wrong position, because I didn't look it up.  If the rotation is in the wrong direction, move the negative to the other sine.
Bruce
Bruce Ammons
Ammons Engineering
(3,811 Views)
hi Bruce
I always use bellow vi for this reason
but as I told in my first post you can do this just when you have
position of two points in one  2d plate ot you have position of one point + rotation angle of 2d plate
with just one point it is impossible to find other point position based on that point
(3,798 Views)
BruceAmmons 已写:
Bruce
(3,748 Views)
Hatef.fouladi 已写:
hi Bruce
hello master:
  yes. i used the way which Bruse talked about. and then i used 2D Cartesian rotation.vi to finish the code. you are in the same way~ thanks for your reply.~
(3,746 Views)
this.pngyour welcome ,also you can use above vis for geometric calculation in image
(3,738 Views)
