Yesterday I tried the camera on XP 64bit. The problem was the same on NI MAX. But in Vision Builder the camera worked properly. I keep the camera acquiring + processing images around half an hour, and no error comes out. How a device can work in VBAI while not working in MAX?
I know this adapter has known issues, but knowing this is not a solution to the problem. It is obviously a driver problem yet, if a device does not work properly in MAX but working in VBAI, I think there are also problems with NI software, not only the adapter or driver.
Thank you for your kind helps.
