Machine Vision
Frame Grabber
Hi All,
I am a piece of industrial equipment that has an 8-bit (black and white) image stored in memory.
The stored image is redisplayed on the PC monitor using a custom card that is located in the PC.
The signals from the stored memory are:
1. Analog signal (video)
2. Vertical sync output: TTL 16.66 ms time period
3. Horizontal Sync output: TTL 63.33 us time period.
I need something that will accept vertical and horizontal TTL sync (above) and the analog data.
I think the NI frame grabbers may work but the question is which one.
There are a number of NI cameras that appear to be compatible but I'm unsure and would hate to purchase something that doesn't work.
Any ideas?
Earl
(4,177 Views)
Hi Earl,
I would look at the documents I include below, for information on how to choose a camera.
Once you know what camera you would like, I would start looking into frame grabbers.
Frame Grabbers
https://www.ni.com/en-us/shop/category/machine-vision.html
Best wishes!
Amanda B.
(4,119 Views)
