Another trick is to acquire the image in color using the Bayer filters, then convert it to grayscale. The end result is the same. A little more complicated, but cheaper than getting the Development module for a single VI.
You might also be able to select a different mode for the camera so it outputs grayscale instead of Bayer color.
Bruce
Bruce Ammons
Ammons Engineering
