06-30-2015 10:42 AM
I've started a project using Vision Development Module and I'm stuck in saving some templates to a folder.
I tried many other ' methods' using the same Imaq Write File 2 and all have the same error...
Below it's a basic example.
Maybe somebody can provide a correct solutions or give me an idee about what might be wrong.
I'm loosing my mind soon 🙂
PS: I gave Full Control Acces to all users ...
Thanks in advance!
Solved! Go to Solution.
06-30-2015 01:53 PM
First a few suggestions
1. Dont use express vis. Just use a grab/snap inside the while loop.
2. If you are trying to save a template that labVIEW can recognise then you should save as png with vision info.
Coming to your issues. What is the file path you are specifying?did you try some other file path?
06-30-2015 04:54 PM - edited 06-30-2015 04:58 PM
Thanks for your reply!
Actually, in the main vi I'm using grab function.
The thing is... i'm using Folder Path instead File Path... If I'm creating a control from vi's path terminal, it will create a File Path control which needs : "the complete pathname, including drive, directory, and filename, of the file to write". But I cannot have a filename before I get a picture. Maybe there is another vi which has to be used before, for setting the filename???
Don't worry about "F" drive. I've already tried the other drives and same thing.
Thanks!
07-01-2015 12:34 AM
use "build path" function to add name to the template. You can do this in numerous ways (as a constant, dynamically, etc...).
An example of using a constant is shown below:
K
07-01-2015 07:10 AM
Thank you!
It's working with Build Path. Using for Base Path a folder and creating the filenames with Prompt User for Input, that's exactly what I want.
Attached, there is a basic example of .vi for saving images using the webcam ( for beginners in vision like me:) ). I converted it for LV 12 .
Thanks again!
