09-30-2015 04:25 AM
I'm trying to extract the crosshair in the attached image in order to detect the edges of it. An alternative would be to remove the green cross in the picture.
Does anyone got an idea how i could do this with Vision?
Thank you!
Best Regards
09-30-2015 07:56 AM
I could solve the problem with the Vision Operator-VIs. Especially with the IMAQ Compare VI comparing to a constant.
Regards
10-01-2015 07:10 AM
Extract the grren plane from your image
Then run an edge tool top to bottom and then one bottom to top. Average the two lines
Repeat this but now do the horizontal axis
Intersect of the two lines and you have the coordinates of the centrepoint
Mike
