Machine Vision
Extract crosshair in a image for edge detection
I'm trying to extract the crosshair in the attached image in order to detect the edges of it. An alternative would be to remove the green cross in the picture.
Does anyone got an idea how i could do this with Vision?
Thank you!
Best Regards
(3,871 Views)
I could solve the problem with the Vision Operator-VIs. Especially with the IMAQ Compare VI comparing to a constant.
(3,850 Views)
Extract the grren plane from your image
Then run an edge tool top to bottom and then one bottom to top. Average the two lines
Repeat this but now do the horizontal axis
Intersect of the two lines and you have the coordinates of the centrepoint
Mike
(3,824 Views)
