Running the "regsvr32 NIVBAITestStandAPI.dll" command, the following error is returned...
"The module NIVBAITestStandAPI.dll may not be compatible with the version of windows that you are running. Check if the module is compatible with an x86 or x64 version of regsvr32.exe."
Running Windows 7 Professional, 32 bit. TestStand 2012 and Vision Builder 2014. Cant seem to figure this out. New to Vison Builder
UPDATE: found the solution in another post. regsver32...was successful. However, Vision Builder icon still not available/showing in TestStand
