08-11-2015 04:21 PM
While trying to deploy a VI on a CVS-1458RT, I get the following error at the end of the Deployment Status in the Deployment Progress dialogue box:
Deploying NI_Vision_Development_Module.lvlib:IMAQ Draw TextNI_Vision_Development_Module.lvlib:IMAQ Draw Text loaded with errors on the target and was closed.
LabVIEW: (Hex 0x627) The function name for the nivision.*:LV_DrawText_v2:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Deploying NI-CVS-1458RT-01A1F26F Container
Deployment completed with errors
I have no problem running the code on my PC. Any idea what is going on?
08-12-2015 02:45 PM
Hi SoheyIV,
Have you already deployed the VDM software to the CVS target? You can do this by right clicking the Software tree under the CVS-1458RT in MAX and selecting 'Add/Remove Software'.
