03-19-2015 11:01 AM
The sensor we are using is Goodrich SU640KTSX. I can run SUI image Analysis 3.1 software, Measurement & Automation software, and MATLAB code on an XP machine with no errors when grabbing images. We are tying to build a newer PC;
Dell T7500 with Intel xeon CPU x5650 @ 2.67GHz
Memory; 12GB
OS Win7 64-bit
Camlink card is NI PCIe-1430
Nvidia QUADRO 4000
The error we get is "Error -1074397153 occurred at IMAQ Grab Setup.vi / Cannot detect recognizable video source" when using the SUI image Analysis 3.1 software or MATLAB code. When we use the NI-IMAQ i/o 2.3.1- Measurement & Automation I can snap, grab and record without any error.
Any help on this would be great
03-20-2015 02:27 PM
Airabas
Unfortunately we do not test or support 3rd party software listed in your post. It is possible that OS or HW changes could have caused this issue.
I think your best option is to contact individual manufactures to get more details on this problem.
03-26-2015 01:51 AM
Let us know which standard your camera is following (whether it is cameralink or ethernet).
Check this link for error info: http://digital.ni.com/public.nsf/allkb/3434173630CBC97686256F8000536593.
If at all it is cameralink camera make sure that you are following proper trigger sequence for your camera. As u are grabbing frames in MAX and not in other acquisition softwares it might be triggering issue or cables problem.
