07-31-2008 10:11 AM - edited 07-31-2008 10:19 AM
08-05-2008 12:48 PM
02-12-2015 12:31 AM
HI German Coast Guard,
I need help regarding CAMERA CALIBRATION ...
my Camera has following properties ,
5MP Gige Camera
Sensor Size = 2/3"
Optical Magnification = x4
FOV = 1.65 mm x 2.20 mm
I CAN ABLE TO DO CALIBRATION USING VISION ASSISTNAT.(Creating calibrated image )
(POINT COORDINATE CALIBRATION) ..
I NEED TO CREATE VI FILE SO THAT USER CAN CALIBRATE WITHOUT VISION ASSISTANT ...
IS IT POSSIBLE TO DO ?
02-18-2015 08:55 AM
Hello saran1988,
Since this forum post is seven years old, I would suggest starting a new thread in order to get more visibility and attention from the community.
You should definitely be able to do point coordinate calibration using vision assistant. If you go to the shipping examples in LabVIEW (Help > Find Examples...) there are some good examples under Toolkits and Modules > Vision > Calibration you may want to check out.
02-18-2015 08:58 AM
