Hi all, I run into a serious problem:
I have two PC with two cameras each (four total) and from two weeks ago, two cameras, one for each PC, are disconnected continuously causing the following error: Camera has-been removed 0xBFF6900C
They are also not always the same camera, but always two and one in each PC ...
I have also found that the camera that disconnects, lost many packages continually .
Any idea what happens.?
For 4 months has worked well, and in other instalation just do not have that problem ...
A greeting and thanks for your help.
