04-30-2014 03:47 PM
I'm not sure what to do. The controls must be a little different for GigE cameras, because I haven't had any problems changing them for other types of cameras.
Bruce
04-30-2014 04:00 PM
Actually I tried to change that area option at my laptop's integrated webcam not GigE camera.
04-30-2014 10:45 PM
So the problem is with the laptop camera, not the GigE camera? Why post the MAX screenshot of the GigE camera? Or if the problem is with the GigE camera, why try a solution with the laptop camera that works???
Make sure you are clear about which camera you are having problems with, and try the solutions with that camera.
Bruce
04-30-2014 11:39 PM
05-01-2014 02:59 AM - edited 05-01-2014 03:00 AM
@BruceAmmons
I don't have chance to access GigE camera after I posted my first question at topic. Because it's in laboratory when I saw your answer after I came to home so I tried do it with my laptop camera to if it works in laptop camera.
@BlueCheese
When I tried use other source(second option at first screenshot of my first post) of camera(I think it's ethernet) after waiting some moment I get "IMAQdx Timeout Error 0xBFF6901B"
05-02-2014 02:34 AM
can you dissconnect the other cameras temporarily and try using this camera alone?
05-02-2014 02:46 AM
Can I disconnect my integrated webcam on laptop?
05-02-2014 10:42 AM
In addition my output images are not distorted when I seperately tested them in NI MAX, NI Vision Assitant, NI Vision Builder.
05-05-2014 09:52 AM
When I tested my cam at Vision Acquisition SubVI's properties section it works great(Attachment 1) but when I run VI output is still distorted(Attachment 2). Is not there anyone who experienced and dealt with same problem or I am the only person who experienced this?
05-06-2014 05:33 PM
Hi Butterworth,
Have you tried some of our example code? To get to the example code go to Help>> Find Examples in LabVIEW. In the following window navigate to Hardware Input and Output>>Vision Acquisition>>NI-IMAQdx>>High-Level>>Snap.vi. If this still doesn't work I would recommend going to the example located at Hardware Input and Output>>Vision Acquisition>>NI-IMAQdx>>High-Level>>Grab and Attributes Setup.vi. Make sure that the attributes in this vi match with your settings in MAX. Also is your GigE camera connected directly to your computer?
