07-18-2014 09:09 AM
Hi Vision Gurus,
I need to create multiple images, so to reduce wiring I thought I'd put them into a cluster. But when I do so, they are all called "New Image", which is not the name I gave each one when I used IMAQ Image Create. Iexpected each image to have the name I gave it.
Can anyone explain what I'm doing wrong?
Many thanks.
07-18-2014 02:38 PM
The "Name" you give an image using Imaq create image.vi can be though of as a pointer to the actual image data.
The name of a control in a cluster is just the label of that control. The two things are not related.
If you need to carry multiple image references (named images) in a single cluster element, then simply create multiple image controls (or constants), and then wire up to the corresponding named image wire.
07-19-2014 05:33 AM
I think the name of your image label will get reflected in the cluster .
07-21-2014 08:17 AM
That works. Thanks for the help.
For anyone else who has the same question in the future, I create an image indicator (an actual image displayed on the front panel) with whatever name I need, then turn into into a constant and wire it up to a Cluster function. That way, when I unbundle by name I see the image name. Not sure if it's the 'proper' way, but it works for me.
07-31-2014 08:09 AM
For anyone also reading this.. you can simply create a constant for the input of the bundle to cluster function, and rename the labels on that.
