03-15-2014 04:09 AM
Hi Guys :
I ask the same problem five years ago (see the first link , ohh , can't image that's five years ago , everything changes ...... )
and fixed in following thread(windowxp based ), but now i met the same issue at Win 7 , can't find the config file under
‹root directory›\Documents and Settings\All Users\Shared Documents\National Instruments\NI-IMAQdx\Data
http://forums.ni.com/t5/Machine-Vision/Camera-ID-Settings-Problem/m-p/906249#M22962
http://digital.ni.com/public.nsf/allkb/61405DCC1A09CDE686256F00005AA2B5
http://digital.ni.com/public.nsf/allkb/AD1041C9B4B27240862570DD0068605B
Thanksw
03-17-2014 07:34 AM
Any feedback ?
03-17-2014 05:31 PM
Hi adobefree,
The camera file needs to be in the data folder in order for it to work with the camera. If it is not there, then it probably means it's not a default camera file that comes with our software and you need to get it separately. You can create your own, or contact the manufacturer of your camera to see if they offer it.
03-18-2014 01:21 AM - edited 03-18-2014 01:23 AM
I can see the camera every time i open the NI MAX explorer , and i can see the settigns changes have been stored there , which means it already been a default camera .
But i just can't file the config file undet data folder , could you check what's the path of config file in WIN7 enviroments ?
03-18-2014 07:18 AM
03-19-2014 08:32 PM
I found them , thank you guys!
