07-27-2014 07:50 AM
Hi all,
Please, here i have some program performing two different process. I have only one camera and i need to set the camera exposure time for example to 200 microsecond to perform the first process ( this process takes about 30 seconds). After that the exposure time should be changed to 400 microsecond to perforom the second process. that is easy if i have 2 cameras . So please can you help me to change the exposure time to the desired value after the first process finish.
Appreciate your help.
Thank you
07-30-2014 01:58 AM
well you're doing it at the start... you simply have to do it again using the same IMAQdx property node between the 2 processes.
I've modified your VI to do it, take a look and try it out.
Epictetus
07-30-2014 08:11 AM
Hi TITou
Thank you, it works well now.
Appreciated
