04-27-2012 12:05 PM
Hi All,
I am acquiring form a camera using an architecture very similar to the one posted here. I am registering my camera for the Frame Done event and it is aquiring images with no problems.
What I would like to do is stop the acquisition. I have tried to deregister by creating a case where I register for an null reference (similar to how you dynamically unregister for a user or control event) but this threw up an error. I also tried to increase the 'buffer interval' to a huge number - this stopped the acquisition but when I tried to restart it the code hung - perhaps it was waiting for u32 frames to be acquired before acquiring again.
Is there anyway I can do this? Or would I be better off putting my code in a larger case structure where I can close the camera and re-open it later?
Many thanks in advance,
Dave
Solved! Go to Solution.
04-30-2012 11:21 AM
Hi Dave,
When you say stop the acquisition do you mean stop the program from running without error, or do you want to stop the acquisition and then restart it pragmatically?
04-30-2012 11:27 AM
Hi Matt,
I'd like to be able to stop and then restart the acquisition programatically. My thought had been to dynamically unregister and then re-register for the frame-done event by using an empty reference. Unfortunately this threw up a camera error when I tried it.
Thanks for your help,
Dave
05-01-2012 09:55 AM
Hi Dave,
Is there any options for triggering with your camera?
Regards
05-01-2012 10:46 AM
Hi Matt,
My plan is the final version will run both in 'live mode' and also with the option of an external TTL trigger. However I am focussing on implementing the live mode first.
Regards and thanks,
Dave
05-04-2012 09:56 AM
You can actually just use 'Unregister for Events' to unregister it and then implement the same 'Frame Done' Event to start it up again.
05-08-2012 06:07 AM
Hi Randall,
I'll give that a try - thank you very much,
Dave
05-08-2012 06:20 AM
That worked thank you![]()
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
