02-23-2015 03:44 PM
Hello, I am trying to determine if I can use the NI 1473R PCIe FPGA framegrabber in a PC based NI real time OS computer. Does anyone know if this is possible? I would think so as it should appear to the real time OS as an FPGA target that can transfer its data over DMA, but I wanted to make sure the drivers would work in NI real time.
I appreciate any info on this!
Solved! Go to Solution.
02-24-2015 04:38 PM
lukepike,
Yes you can use this device with NI Real Time OS.
02-24-2015 09:16 PM
03-06-2015 08:19 AM
Thank you for the info! Yes, I gathered that I would have to manually configure the camera going through a framegrabber like this. I thought I saw someone mention a basler API to do that, I'll have to look for that again.
Thanks again!
