10-10-2007 06:27 PM
10-11-2007 03:11 PM
12-10-2007 08:01 AM
I also tried to use OpenCV with Labwindows CVI. But I get errors with präproc. in cxtypes.h although only includfing "cv.h"
Did someone manage to use OpenCV already ?
Would be nice to hear.
12-12-2007 01:45 PM
12-13-2007 01:50 AM
Hello Guenter,
thanks for your reply.
I already managed it. OpenCV is working. Just had to go around Borland and MSC defines.
In cxtypes.h: #define CV_INLINE static // Modified to work for, here
and two errors for typedefs: "long long" i.e. "long int"
Just bind in cv.h, cxcore.lib and cv.lib
Then one just has to supply all appropriate dll within exe path.
12-13-2007 01:50 AM
Hello Guenter,
12-13-2007 01:50 AM
Hello Guenter,
04-10-2008 11:21 AM
01-22-2013 02:40 PM
OpenCV does work with LabWindows. If you successfully "installed" the latest openCV, which is at the time of my post version 2.4.3, the header file "core_c.h" along with corresponding lib and dll files must be added to you project tree in order to use openCV functions. "core_c.h" includes "types_c.h" which for some reason LabWindows/CVI doesn't really like. The problem starts on line 137:
The only option CVI likes is the last one (CV_INLINE static), so simply modify this segment so that it's the only choice and compile!
01-22-2013 02:41 PM
This how I have it BTW...
