07-31-2015 01:53 PM
Hi there,
I'm using a Point Grey Blackfly USB3 camera for an application. I wrote an application on Windows 7, and deployed the executable to Windows XP.
On Windows 7 I can use the point grey frame grabber, or view the camera in MAX or my LabVIEW application without changing drivers.
On Windows XP I can use the point grey frame grabber. I installed MAX as well as my application with the IMAQdx 14.5 runtime and Vision Acquisition software, but cannot see the camera in MAX. The camera originally showed up in Device Manager as a Point Grey USB3 camera, but I can change the driver to NI-IMAQdx USB3 Vision Device, and it still does not show up in MAX.
Please let me know if you have any experience or ideas on the issue. Thank you
08-05-2015 03:16 PM
If you are in development on XP, are you able to capture images? What exact Point Grey devices are you using?
08-05-2015 03:53 PM
Hi Tanner, I do not have LabVIEW installed on the XP machine. I am using the BFLY-U3-20S4M-CS Camera.
08-06-2015 12:36 PM
You said that you are able to use the Point Grey Framegrabber in XP. Are you saying that you're able to acquire images using thier software and driver, just not MAX? Does the camera work at all on the XP machine?
08-06-2015 12:42 PM
I was saying that it acquires images using the Point Grey frame grabber, but not in MAX. Now it talks to MAX as well!
Before I had just deployed the application and it installed the IMAQdx runtime, and the camera did not work. After popping in the Vision Acquisition CD I ran a full installation, and the camera is now working!
In LabVIEW 2013 deploying a vision application would include the IMAQdx drivers, but now in LabVIEW 2014 it deploys the IMAQdx "runtime". I am not sure what the difference is, but I never had a problem deploying applications written in 2013. I think this is the second time I tried to deploy an application in 2014 and both times resulted in complications. Last time it completely wiped out compatibility with older applications. Please take note!
08-07-2015 12:24 PM
Glad to hear you got it working, and I appreciate you letting us know what you did to get there.
