07-13-2015 02:31 AM - edited 07-13-2015 02:33 AM
I developed a PXIe system which uses 4x Basler acA1300-60gc cameras. My customer is reporting a strange issue where settings applied in NI MAX are not being retained after shutting down the system.
Here's what we did:
However, at step #5, the application no longer gets the correct video format; we need to go back to NI MAX and re-select "Bayer RG 8". According to the customer, other settings sometimes change too after powering down, but the most noticeable one is the pixel format.
I did not encounter anything like this during development (I had 1 camera for testing), but the software is now deployed as an .exe on a different PXI controller, there are now 4 cameras attached, and the system is at the other side of the country so I unfortunately don't have access to it.
I'm at a loss to explain this; what might be the cause, and how could we fix it? Are NI MAX's settings getting overridden by the camera's on-board settings? (I could programatically applying settings at startup, but that would remove the operator's ability to configure the system through NI MAX)
Thanks!
08-05-2015 03:01 PM
Hi JKSH,
The attributes should be saved in the .icd files stored in C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data for each camera. You could try to replace these with the correct ones on your development computer. I would recommend programmatically setting attributes as a best practice.
