01-25-2013 02:56 AM
Time out came up on Camera File Generator
Hi
Recently I use Camera File Generator Version 2.1.1 to control a CamraLink camera through IMAQ PCI-1428. When I grab the image "Acquisition Timeout" message came up. I changed smaller image format, but it was still same. I succeed communication with this camera through another serial communication software. It seems camera works, but an image does not come up.
And one more thing, I just want to use a camera with default setting. I expect I do not need to send any serial command. Should I do some action ?
Thanks lots,
Kevin
01-25-2013 04:40 PM
Hi Kevin,
Are you trying to grab using Measurement and Automation Explorer? If so, try going to the Acquisition Attributes tab in MAX and lowering your Packet Size.
01-30-2013 03:09 AM
Hi Burrito,
Sorry for late respond, Now I got an image after changed the camera setting and setting on IMAX. I can see an image on both of software. It seems camera was not recognized on IMAX. This was main reason. Thank you for your help.
Best,
Kevin
